In with the new IMS bearing. Installing the bearing is not easy; you don’t want to be laying on your back or stomach while trying to install the bearing. The car needs to be high enough so you can at least sit or stand while doing this task. No beer drinking during this task!! I had a heck of a time lining-up the bearing with the IMS shaft (no I was not drinking beer). The trick was to wiggle it back and forth, while trying to insert it, and feel it slip-in the shaft a little before hitting the insert tool with a “dead blow” hammer.
