Old 04-28-2011, 11:07 AM   #22
Gilles
Originally Posted by Flavor 987S
I guess I am wrong about OEM tire pressures for an 986. On my 987S with 19" inch wheels, OEM spec's are 34F/37R. I tend to run about 1 PSI lower than spec. Michellin PS2's.
Did not realize front tires pressures are so low (30 PSI) on a 986.
Flavor, also on the 987S w/19's
I found out that running about -1 on the rears (34/36) the tires wear more evenly, otherwise the rears will wear too quickly on the inside.
Gilles is offline   Reply With Quote
