					Originally Posted by ekam
				 It's not the problem of used tires. The problem is unknown age & wear pattern. Were they mounted on wheels within proper recommended width? Were they heat cycled often? That's just few of the many problems when you buy used tires. OP didn't state how the tires are worn when they were replaced.
Provided his mechanic with 30 years of service knows what he's doing, I would put my bet on the tires.
I have pics of two different sets of tires that wore the same exact way.  I just don't know how to post them!! Grrrrr...
The tires wear from the inside out on both sides.  Your pic of an over-inflated tire is the best example.  However, that many coincidences would be impossible, as  each set was installed by different tire stores.
