Thanks for the suggestion, Paul. I tried what you posted and after sitting for several minutes (4 to 5) I never heard the throttle motor. I'm guessing your suggestion has something to do with the electronic throttle control and learning minimum position (accelerator pedal or throttle blade?). Regardless, I tried a couple times and could not fix it. Any other suggestions would be appreciated. I even tried disconnecting the battery for several hours. Thanks.
