Old 04-21-2011, 07:53 AM   #1
papasmurf
I've got the same sound with mine
67k on 2000 base. At idle you can hear the ticking sound but it goes away if you rev the engine to 1200-1500 and hold it there briefly. If you let off the gas and let it idle for a moment again, the sound comes back....most noticeable under really light throttle application like when I leave a stop or am backing out of the drive. I am pretty sure it is the lifters. They are hydraulically actuated. I am not sure what to do to fix the problem as the car has always been this way since I have had it. Perhaps changing to a different grade of oil may help some...I am still running 0W40 M1.
papasmurf is offline   Reply With Quote
