Old 04-20-2011, 11:48 AM   #4
AtlantaBoxster
paulv
Yes, the O2 sensors are still swapped. I did not move them back. Since I switched all the O2 sensors, I did remove and put back the harness. If the harness was not seated properly, would I get a P0430 code or something else?
Just ordered this little jobby. Will see how well it works. Only $38 bucks, worth the risk. Seemed fairly decent reviews.
I'll let you know the results after I test it.
http://www.amazon.com/Crescent-OBD2-Multi-Protocol-Diagnostic-Scanner/dp/B001MT0XPK
AtlantaBoxster is offline   Reply With Quote
