					Originally Posted by dirkdiggler
				Cool, thanks....that makes me eager to try them out!
anyone know what the Ohm impedance will be at the amp with qty 4 speakers that are 6ohm each??
I can't tell you without seeing the wiring to determine if they are wired in parallel or series. One way gives you less resistance the other way will double it.
Here is a link with photos to show you how to connect them either way. It would be helpful to know what the amp is expecting to "see" at the speaker connections.
http://www.bcae1.com/spkrmlti.htm
Good luck!
