Old 04-17-2011, 10:25 PM   #2
graemewior
if you remove the drivers side tire and the plastic cover that encloses the wheel well you will have access to the cable that runs from the trunk release inside the car to the front trunk. carefully pull towards the car on the cable and it should pop the front trunk. i had to do the same thing once before.
graemewior is offline   Reply With Quote
