If you bridge your fifth channel - ensure that the amp and spearkers are capable of running at 2 ohms.
Also not sure if you would need to amplify the rear spearkers, they are only for a very smally amount of fill. That being said, would be handy to be able to switch them to high pass and set the gains indepently (although I can do this with my headunit, most modern quality units can)
Otherwise sounds good. Goodluck!
Sam
