Thread: Pse ???huh!
Old 04-12-2011, 03:27 PM   #10
JFP in PA
Again, there is nothing that needs to be "set", the default position for the PSE is “open”, or loud; if you take one out of the box and put it on the car with out connecting the vacuum lines, it is already in the “loud” configuration. To get it to close, you have to connect the vacuum lines to the diaphragms, or pull them shut and wire them in the “closed” position; otherwise it is open.
