Originally Posted by jaykay
Hmmm....sound is subjective (an unplanned illiteration) I see!
The O2 sensors on your model should be right in the headers which incorporate the primary cats. The secondary ones are not monitored so there should be no problem.
The secondary sensors are not monitored? If this is true then why are they there for 1? and why have I seen multiple times on here that when you go to replace a bad O2 sensor to replace all 4 at the same time?
Is this true on my 00 S? or?? Can someone explain please?
