Old 04-09-2011, 05:35 PM   #12
Mike_Yi
Originally Posted by ChrisZang
b) The T-piece won't work as the oil sensor must be where the oil flows not where it basically is static
So, I keep looking....
I assume they mean the oil pressure requires flowing oil. Or do they mean temp? Pressure should not need flow. Pressure is pressure and it exerts force in all directions. I could see oil temp needing flow though. Not sure how you could rig that. Have you tried on the NASA forums? Have you tried contacting any of the teams in the Continental Tire Challenge Series that run Boxsters? I'm sure they have oil temp gauges.
Mike_Yi is offline   Reply With Quote
