Old 04-09-2011, 10:05 AM   #10
JAAY
JAAY's Avatar
If your car is turbo'd then you have had the dme reprogrammed correct? Then your tuner could have done that for you. Even if that was done you would have had to redo the valve springs and valve train. The limiter is there because that is the design limit of the motor.
Pics please. Interested in seeing the kit. There only a few out there.
JAAY is offline   Reply With Quote
