There is a spot to add an oil pressure sender, or a T where you can add a pressure and temp senders, on the upper, left side of the engine. It's just above, and slightly in front of the most rearward coil pack on that side of the engine (too lazy to look up cylinder number). From what I hear, that is where oil pressure is checked at the factory or something. I also think that is where the 996 pressure sender is located (though it would be on the right side with the engine installed in the 996).
I'm just going to mount the gauges in the GT3 console delete panel.
