It may be the open diff instead of, or in addition to the alignment. If the transmission favors one side, you may be getting more wheelspin on one tire than the other. Could be due to some slight difference in suspension geometry or cv joint geometry on one side. In which case, LSD would help even tire wear. But I'd suspect the alignment of the rear suspension first.
