Old 04-04-2011, 11:52 AM   #21
Burg Boxster
Originally Posted by J Tinsby
Right... but if you put power to the front ones you need to NOT have 12vdc going to the back ones....so you need at minimum a relay or printed circuit to isolate the front LEDS power source from the rear ones. Depends if they are getting power separately from the switch (which I doubt is the case).
Then conversely when you want the rear ones on, the power has to bypass that isolation circuit and get to the front ones.
Other than that your idea is fine.
I thought you were talking about an aftermkt strip of LED lights per the OP's message not the OEM set up. That being said, there still might be a way (by the dealer using PIWIS system) to get yours to do what you want. There are a ton of 'hidden' features available. In my 997 I can turn on/off DRLs (though it does turn the rear one too) if I want to or not thru the PCM individual memory settings.
