Old 04-04-2011, 08:13 AM   #18
J Tinsby
J Tinsby's Avatar
Yes well..
Originally Posted by Burg Boxster
You could easily rewire them to a switched sourced so they automatically come on, if you so choose. This would be especially simple to do if the installer ran the wire to the fuse panel in driver's footwell. Even if not, it'd still be easy to do, just need to find out where they got the + source from.
Right... but if you put power to the front ones you need to NOT have 12vdc going to the back ones....so you need at minimum a relay or printed circuit to isolate the front LEDS power source from the rear ones. Depends if they are getting power separately from the switch (which I doubt is the case).
Then conversely when you want the rear ones on, the power has to bypass that isolation circuit and get to the front ones.
Other than that your idea is fine.
"Never force it.... get a BIGGER hammer!"
J Tinsby is offline   Reply With Quote
