If the drains are clogged up that's where water will end up. I had the same problem on my97 on the passenger side only. It is hard to understand how water gets to that point, but that's where it goes. You can test with a water hose and watch for water running out the drain holes on each side. They should run freely right through as you run water down the top. You should be able to search on the problem here or on Rennlist or pelican. I can't recall which forum I used at the time.
2001 Boxster S 3.6, 2003 E46 M3, 94 968 Cab, 80 911 Weissach Edition, BMW 1200 CLS
