Originally Posted by clickman
You can try adjusting the stops under the hood. But you may get an uneven or too large of a gap between the top of the bumper and the front edge of the hood.
Okay, so this thread has made me take a second look at this issue. If it's a matter of adjusting the stops, it should be an easy fix. But no....at least on mine, stops aren't adjustable. I have some rubber bumpers on the hood and some recesses in the body to accept them. No, it looks like the only possible fix is removing the plastc cover to get access at the latch itself. I think I might try a little WD 40 first as mentioned above, but I don't think that'll solve my problem. Upon closer examination, when my hood is closed, it rests slightly below the top of the bumper.
