Old 03-31-2011, 10:27 AM   #10
PhilNotHill
Originally Posted by stephen wilson
You don't need to do all that with the remote, at least on my 987. I just open the door with my key, put the key in the ignition fairly quickly, and turn it on ( but not start), no alarm problems. There's also no real need to do the hot oil check. I check the level cold every time I get in the car. It will read a bit high after sitting, but that's no problem.
I think mine says the oil is not warm enough to give a reading. I will double check.
PhilNotHill is offline   Reply With Quote
