i've made several 2500-mile roundtrips in my 01 now. check the fluids, change the oil, check air pressure in tires (and spare). take a hat, some sunscreen and sunglasses for the sunny top-down portions. have fun. get a motorclub membership if you're worried.
i have had something go "wrong" on each of my trips to dallas, but i don't attribute that to the drive just normal wear and tear that would have happened somewhere else.
- engine mount
- alternator
- cat rattle
i've learned to take an extra quart of oil because it's nearly impossible to find the correct weight in the small podunk towns that dot the highways. no matter the price, don't skimp on good gas (octane and brand). i also take a radar detector and handheld cb.
bring an ipad or smartphone to look on the forum and post if something does go wrong. decent chance someone else is out there you can go to lunch with while your car is being fixed - or you can find the info to fix it yourself.
bottom line is have fun. you'll waste a good trip thinking "what's going to happen to it" the whole way.
ps. avoid arkansas if possible - the roads are horrible! and don't forget to flash your lights at other p-cars. some of us still do it!
