Old 03-19-2011, 10:25 AM   #1
tonycarreon
tonycarreon's Avatar
Originally Posted by baileymc
How do you take the headlights apart to clean off the yellow??
1. if the yellow is on the outside due to sun damage, you can get some lens restoration kits and try it. i have not had much luck with them - they do a little cleaning, but not enough to justify the time i spent trying (i'm a fairly impatient person, fyi).
2. if the yellowing is on the inside then your best bet is going to be to get new headlight assemblies. they're not really designed to come apart though some people have been able to by heating them in the oven (don't use the one you cook in) to melt the glue enough to remove the larger parts - do a search on the forum and google for links.
