Old 03-15-2011, 10:32 AM   #1
BYprodriver
BYprodriver's Avatar
Porsche says do not lube "cone" to wheel contact area. I believe the purpose of the cone is to reduce friction between the lug bolt & wheel surface. I use a thin coat of anti-sieze on all lug bolts/studs & if I had the problem you do I would lube under the bolt head also. Basically you want the "cone" to not move & the bolt to be low friction for a true torque reading. I drop my install torque to 90 ft.lbs. due to the reduced friction.
