Old 03-14-2011, 05:16 PM   #2
The Radium King
The Radium King's Avatar
the sensor on the axle is your speed sensor - not the problem.
the brake wear sensor is a simple circuit - a loop of wire. when the pads wear down to the sensor, the exposed wire gets worn-through and opens the circuit triggering the brake wear light. once the light comes on you can't reuse the sensor. if you unplug the sensor completely the computer sees an open circuit and puts the brake wear light on. your solution: new sensor or cut your sensor near the plug and twist together the two wires you find there. comupter will see a continuous circuit and turn off the light.
