Originally Posted by beeny
Hello, it's my first post on this forum so welcome everbody. My name is Marcin and I'm from Poland. I have a Porsche Boxster 2001 for a two years.
In winter my boxster stands in garage. Few months ago when i wanted to start my car battery discharge. After charging car doesn't working Starter is working but nothing else. I replace the spark plugs and i find out the fuel doesn't come to engine. Can I do something else or I should carry my car to the service which is 300km from home? I am waiting for your suggestions.
Welcome to the forum. Try pulling your fuel pump relay out and push it back in a few times. sometimes there is a little film that builds up. Also check you fuel pump fuse make sure it is good. If still no luck then replace the relay, otherwise it will be a trip to the garage and maybe your fule pump seized. Good luck
Harry
