As a quick test for the starter problem, switch on your headlights and see if they dim when you twist the the key. If the starter fails to turn over and the lights dim, it means the starter motor is drawing current but failing to spin up. Could be a failed starter or faulty bendix.
If the lights remain bright when twisting the key, could be a faulty ignition switch (my guess) or starter relay. Put a voltmeter on the bendix wire (second person required)and see if you have 12 volts there when the key is in the start mode.
2001 MV Agusta F4.
