Old 03-11-2011, 01:46 PM   #37
Dale_K
The Tiptronic service basically means draining the fluid in the pan, dropping the pan, changing the filter and refilling the fluid, per the 101 projects book. Possibly draining and refilling a second time to get a more complete fluid replacement. I think it's supposed to be done at around 80k miles. My car displayed a CEL for a vacuum leak but there was a 0740 code too, which has to do with torque converter clutch operation. It shifted a little funny going up hills under light load when cold. Worked OK after it warmed up. I'm hoping the fluid replacement will fix it but it might need a new torque converter.
Dale_K is offline   Reply With Quote
