Old 03-11-2011, 05:02 AM   #13
Dale_K
Originally Posted by shlim8
Dale, just in case u need it - the size of the O rings are listed as 17 x 4 and 47 x 4 (I presume in mm).
I'm now enjoying a stable 80-85 degree celcius coolant temp.... (with the LN lower temp thermostat). It used to spike up to 90+ even with the lower temp thermostat... guess I was losing coolant pressure.
That's good to hear. My car is in the shop for a vacuum leak fix and a Tiptronic service, so I haven't checked it. Part of the trouble with buying an old car is you don't know what things are supposed to look like or whether somebody left out parts in the past. I'm not even sure my car has the o-rings at all. I sure didn't see them when I removed the bleeder valve cap but I didn't take out the circular disc with the holes in the center.
Dale_K is offline   Reply With Quote
