Old 09-14-2003, 06:04 PM   #1
rbboxter
Angry tire wear / alignment issue
I have a 1999 boxter. I am experiencing extreme tire wear. It is related to the rear alignment. The rear toe in / toe out control arms are too long from the factory. There does not appear to be enough adjustment on the cams to set the toe properly without having severe negative camber.
Does anyone know if POrsche has a service bulletin out on this or is there a replacement control arm available that is shorter than orginal?
rbboxter is offline   Reply With Quote
