Old 03-08-2011, 06:13 PM   #25
shlim8
Originally Posted by Dale_K
Anybody have a picture of the tank opening once the bleeder valve is removed? I replaced my bleeder last week and didn't see any o-rings at all. There was a circular disc with a couple rows of holes sort of near the center but I didn't lift that off. Are the o-rings under that? I doubt my bleeder valve was actually bad. The new and old looked and operated identically.
The O rings are below the breather valve housing (the one with a couple row of holes).
My new and old valve were NOT the exactly the same.... It looked the same but after installing it, I realized that the valve (centre plastic piece with the metal ring) was sticking out alittle higher. I thought I messed up somewhere so I removed it - and noticed that the rubber diaphram was alittle thicker. Hence, the valve sticks out more after installing.
It was the second install that did me in.... It was perfectly dry after the initial install. I started getting bubbling from the housing after the 2nd install. Sigh... should have left it. I think my expansion tank just went south.
shlim8 is offline   Reply With Quote
