Old 03-08-2011, 08:25 AM   #3
papasmurf
Make sure you wash the car with some kind
of detergent or soap that will remove any wax on the car in the area you are applying the vinyl. I usually put stuff like this down without the application fluid but a weak soap/water mixture will work okay as well and allow you to float the decal if it needs to be moved. I usually put some strips of masking tape along the edge before applying it as an edge guide to align the top mask layer (the part over the decal) as I lay it down. I have some matte black vinyl at work I think I am going to use to cut out the "porsche" text or "boxster" script to apply to my car.
papasmurf is online now   Reply With Quote
