Old 03-07-2011, 11:16 AM   #17
Porsche_Baller
Send a message via AIM to Porsche_Baller
Where is the AOS??
I had recently cleaned the throttle body when i replaced the MAF i also did that one mod a pedrosgrage.com with the air intake. I figured, wile its off there might as well change it. There was no sign of oil in the intake/ throttle body and the old MAF didn't look bad at all... The new MAF looked exactly like the one i pulled off the car same bolt pattern, and plug spot. It was also a Bosch as was the one that came off of it. As far as Miswired sensors they were straight plug and play they were slotted so they could only go on one way so highly doubt that is the case.
I have to say I'm starting to suspect the ECM or computer myself..
If y'all have some pics or description of where i can find the AOS ill definitely take a look at it.
On a side note do you think the car could have jumped time??
I have to work a 24 tmr but after that ill have a 48 off so ill take a look at the plugs then.
ill get myself a code reader as soon as funding permits... I still have to replace a rear tire. (had a blowout the other day so now I'm riding on one new and one old one)
Thanks for all the help guys i really like brainstorming with y'all
Porsche_Baller is offline   Reply With Quote
