Old 03-07-2011, 09:28 AM   #1
MN 986
MN 986's Avatar
Yes, remove the larger round rubber plug to unlock and remove the headlight unit. IF I remember correctly, you use a 5mm socket and turn it toward the rear of the car to unlock (clockwise for passenger side, counter-clockwise for drivers side), and the opposite to re-lock. It does take a bit of force. Be sure they are pushed/slid all the way back in and maybe even keep a little pressure on them when re-locking.
Good luck!
MN 986 is offline   Reply With Quote
