Old 03-05-2011, 04:14 PM   #1
harryrcb
Crazy Austrian
harryrcb's Avatar
04 Boxster S Engine for SALE 310 hp
THIS IS THE ENGINE YOU HAVE BEEN WAITING FOR - TRACK READY "COMPLETE" ENGINE - COMES WITH LOW MILAGE FLYWHEEL,PRESSURE PLATE AND CLUTCH, COMPLETE EXHAUST SYSTEM, WIRE HARNESS,LOTS OF MODS FOR TRACK USE- AS LISTED BELOW. THIS ENGINE MAKES 310 HP - OIL & FILTER CHANGE AFTER EVERY TRACK (DE) EVENT - NORMALLY WHEN YOU BUY AN ENGINE YOU GET NOTHING BUT THE BLOCK AND INTAKE. THIS COMES WITH ABSOLUTELY EVERYTHING BUT THE TRANS AND CAR . -Never been abused, have the DME print out to show that's it's never been overreved. Milage on engine 51k, the following is a list of mods made on the engine. REASON FOR SELLING- NOTHING WRONG WITH THIS ENGINE. I am installing a much larger Carrera engine in my car.
DYNO RUN ON YOU TUBE http://www.youtube.com/watch?v=VhBB8gBc4VU
1. SOFTRONIC TUNE
2. COLD AIR INTAKE - KN FILTER & ALUMINUM BOX TO SEPERATE FROM ENGINE HEAT
3. MOTORSPORT AOS
4. LN ENGINEERING DEEP SUMP
5. LN ENGINEERING COOLER THERMOSTAT
6. LN ENGINEERING SPIN ON OIL FILTER - USES NAPA OR ADVANCED AP HIGH FLOW FILTERS
7. LN ENGINEERING MAGNETIC DRAIN PLUG
8. LN ENGINEERING IMS BEARING FIX
9. TECHNOLABS INTAKE PLANUM
10. IBP UNDERDRIVE PULLEY
11. HEADERS ( 2" outlet pipe)
12. CAT DELETE INTERMEDIATE PIPES (larger diameter - 2")
13. BORLA MUFFLER
Some parts manufactured by West Side Auto (store coming soon) This is a turnkey system, nothing else to buy, the only thing that can make this engine go faster is strap a turbo on it.(not recommended)
ASKING $6900.00
Crazy Austrian 007
http://www.ws-ab.com
harryrcb is offline   Reply With Quote
