"They put drain plugs on these things for a reason................."
The reason they use drain plugs is they are the simplest and most idiot-resistant method of getting all the old oil and crud out of the engine. They have to be idiot-resistant because, unfortunately, you can’t make things idiot-proof because God seems to side with the idiots……….
snappy comeback!! are you saying god is on your side?
You say that oil drain pumps don't get the crud out. That would be a good reason to use the plug. I haven't heard that before but I'm not doubting it.
