Old 02-22-2011, 01:16 PM   #1
Byron in Atlanta
Accusump Installed this weekend...
It was a pretty straightforward install. The hardest part was the plumbing of the line. I DO NOT LIKE BRAIDED STEEL HOSE!!! Looks good but a ******************** to work with. I noticed that some folks did a connector at the firewall but I just drilled a hole through the firewall and ran the hose through a grommet. I wired the electric switch into the rear wiring harness in the trunk and mounted the toggle switch in the trunk as well. I used the sandwich adapter and spin-on filter adapters from LN. They were really simple and seem like a good solution to me. The trade off is the much smaller filter, but I am going to buy them in bulk and change frequently. I also went with the LN oil pan extension and their magnetic drain plug. If this SOB blows up again, it won't be for lack of oil!!!
Byron in Atlanta
Byron in Atlanta is offline   Reply With Quote
