Originally Posted by ikkaro
As Jaay predicted, it was the water pump. The repair shop said that everything else was fine and that there was no need to test the head gasket. Should I follow that advise?
Here is the breakdown of the repairs:
Water pump replacement:
Labor 605
Material: Water pump $380; Multi-rib belt $80
Thermostat replacement:
thermostat with gasket $100 plus $200 for the labor.
Regards,
IK
You paid too much--I recently had mine done for just under 900.00--included everything you had done plus hoses and collant flush. How could they charge you 200 labor for thermostat when they were already in there doing the water pump?
