					Originally Posted by schoir
				Shlim:
When you get your new breather valve and go to install it, remember the caution about the fragile bolts.  DO NOT over-torque them!
Regards, Maurice.
Thanks for the advice. After I saw pictures of the broken bolts, I understand why ! I didn't even try to tighten the bolts on my current breather valve any more than a millimetre...
I had thought of changing the entire coolant expansion tank, it's still good but has yellowed to the point that I can't see the coolant level. But after reading the instructions on the replacement of the tank, I decided not to...
