Old 02-15-2011, 10:25 PM   #2
BYprodriver
BYprodriver's Avatar
Originally Posted by ikkaro
As Jaay predicted, it was the water pump. The repair shop said that everything else was fine and that there was no need to test the head gasket. Should I follow that advise?
Here is the breakdown of the repairs:
Water pump replacement:
Labor 605
Material: Water pump $380; Multi-rib belt $80
Thermostat replacement:
thermostat with gasket $100 plus $200 for the labor.
Regards,
IK
Inspect the old pump impeller to see if any vanes came off, if they did they can lodge in the coolant manifold & cause overheating. Running the engine hot can crack the head. If it is already back together just watch for intermix or any coolant loss.
