Originally Posted by tawheed
I understand there was a new version of the PSE but isn't fitment the same for mufflers from 00-04? Or is there some new aspect that wouldn't allow me to mount that muffler with the PSE always on on my car?
Thanks again
There is a version for your 02 that Suncoast sells. I have not seen it in person so I am not certain it works the same way mine does, but speaking specifically about my 04 PSE, there are some simple valves on the exhaust. When the valves are open, some of the exhaust bypasses the muffler and is released through an open pipe = more volume. When the valve is closed, all the exhaust is directed through the muffler=less volume.
If your goal is to always have the valves open, I would seriously consider doing the "pedro" modification to your current exhaust or a similar used exhaust. The Porsche version is pretty expensive....about $2k new. The Pedro version can be done for about $200 or less depending on your welding skills or access to a local muffler shop to do the modification for you:
http://www.pedrosgarage.com/Site_3/Make_the_Pedro_Sport_Exhaust.html
Good luck.
