Thread: p1128 and p1130
Old 02-13-2011, 12:14 PM   #2
papasmurf
Had the same problem with mine a year ago...2000 base...
I had already changed the AOS and changing out the MAF made it run alot better. Still has a stumble when cold in the mornings sometimes...curiously it is only when the clutch pedal is pressed in. They did a smoke test to check for vaccumn leaks and did not find any. It would usually throw the codes when leaving from a stoplight. I have been wondering if there is some kind of leak in the brake/clutch setup though I am not leaking any fluid and have never had to top it off.
papasmurf is online now   Reply With Quote
