Did you do some multiple high speed stops to bed the pads properly? It is important to coat the rotors with pad material so you don't get pulsations or severe wear, as you use the brakes harder. Driving on the street does not allow the pad material to get hot enough to properly bed the pads. I'm not sure what instructions EBC supply, but a simple search will give you good bedding guidelines.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
