Originally Posted by mikefocke
Too many times Porsche used old on new parts just because...or the car has a replacement engine...so while we can generalize the only way to be absolutely positively sure is by examination.
The IMS replacement is normally done at clutch replace time along with the RMS (Rear Main Seal) update. So in round numbers for a stick shift car, $2k. For a 3rd gen IMS design such as an '07 surely is...the same parts and labor would be around $4.5k. But depends on what the labor rate is and how you buy the parts. And there are those who do it all themselves or with help from a friend.
Sorry Late model 2005-2008 have to have the motor removed and motor case split to remove and replace IMS this is, BIG BIG $$$$.
1997-2004 can have IMS removed with out having to remove and split the motor case. therefore labor cost is a lot less.
You can buy a nice 2004 and have IMS, RMS and a new clutch done at an Indy, shop for less then $3,000 or Buy a 2009 or newer Boxster and not have to worry about the IMS, 2009 and up no longer have an IMS.
I would not touch a 2005-2008 W/ a ten foot pole, unless it has a warranty. Good luck Dude.
