Old 02-09-2011, 03:28 PM   #1
JFP in PA
I hate to say this, but are you sure you reinstalled everything correctly? Only time I've ever encountered this is when the fork could not depress the pressure plate because something was jammed, so the slave blows out from excessive pressures.
Pull the slave and make sure the fork can be moved freely; if does not, time to pull it all apart again........
