Old 02-09-2011, 12:39 AM   #17
BMAN_986
Bazooka Tube
I've had some great success with a 8" Bazooka Tube in the front trunk. It's different with the bass coming from the front of the car (the pedals vibrate instead of the back of your seat) but it gives me the desired effect ... more bass with my sound system
Pros: I haven't had to build any enclosures or given up any space inside the car and I barely use the front trunk anyway (I still have the spare in there as well).
Cons: unusal bass focus point but def. acceptable.
Wiring up was pretty straight foward because I could ground using an existing ground point and the battery is in the front (for the +ve) . It was a little tricky finding a route through the bulk head. I also had to tighten up some of the trim surrounding the front trunk due to the increased vibration. Rubber washers under the screw points worked very well.
I'll try and take some pics and post.
2001 Porsche Boxster 2.7 L
BMAN_986 is offline   Reply With Quote
