Originally Posted by 88mpa
Hi Can anyone help has anyone fitted a K & N Filter i have tried today and failed the filter just would not push on to the flange in the airbox and can you get the airbox out with the engine in the car
When I fitted my K&N the box it came in had a small tube of grease and instructions stating that the filter was a very tight fit.
The grease was put on the sliding carrier that the panel filter sits in to ease it back into position, there should be no need to remove the airbox.
