Old 02-04-2011, 08:13 AM   #2
JFP in PA
If you are referring to the two M8 nuts alongside the larger hydraulic mount, they are torqued to 33 Nm or 24 Ft. Lb. The mount to transmission varies with the model, base uses M10 torqued to 65 Nm or 48 Ft. Lb.; the S uses M12 torqued to 85 Nm. or 63 Ft. Lb. I have not data for the torx nut below the hydraulic mount as that only comes assembled to the transmission mount bracket and is not sold separately to my knowledge.
