Old 02-04-2011, 07:03 AM   #3
laphan
laphan's Avatar
I'm replacing my clutch and at 47.8K miles. When the mechanic got the transmission out, he found out that the rivets on the on the clutch friction material is 1mm away from touching the flywheel (just in time before it ruins my flywheel). I don't think you want to wait until the clutch is 100% gone (by that time you will need a new $1000 flywheel too).
Also check you brake fluid moisture content (that might cause your pedal issue).
laphan is offline   Reply With Quote
