This is what I was referring to:
Originally Posted by schoir
Rick:
BTW, if you wanted to stick with your old style transmissions (which is not what I have chosen to do), I don't see why you wouldn't be able to swap in the new '03-'04 glass top and frame in place of your '99 top and frame and have it work the same way that the old top worked.
I don't believe that the change from 3 bow to 4 bow frame would have any negative effect on the timing providied by the after-running time built into the "old" system.
It's worth a try if your old "Version A" transmissions and the rest of your system are working 100%. It's easy enough to put the old top and frame back on if it doesn't work for you, at least until you get the rest of the new parts.
Regards, Maurice.
