Thanks for the reply but I'm not sure you're picking up what I'm putting down. I need to get the bolt out from behind the lever arm. I've already got the pulley off but the bolt is longer than the space between the lever arm and the engine case leading me to believe the whole lever arm assembly has to be removed to change out the bolt. Clear as mud?
